Rust Removal and Prep CITRIC ACID
Postby fargo on Sun Jul 03, 2011 9:08 pm
Hi All,
Just thought i would put this up as i have searched around and found this to be the best economical and efficeint way to remove rust from panels and parts.
Most of you may know this already but thought i would share as i did a search and minimal info came up.
Citric Acid Solution to remove rust from panels does an amazing job very little cost and made from citrus.
I can purchase 1kg of citric acid crystals (used in cooking) at a food store for $4.00 and diluted with 15 litres of water makes the solution (add more to make more solution)could probably buy it cheaper and bulk from a chemical supplier
Left over 24 hours does wonders the picture of the parts below have been left in longer around 2 days a very light wire brush then put into the solution removed then a scrub with a platsic brisstle brush and hosed off.
I know coke and alot of other soft drinks and substances have citric acid in them this was easier and cheaper.
After finished a light wire brush then there ya have it.
Any thoughts good or bad let me know!
Before
After
Dean
fargo
Re: Rust Removal and Prep CITRIC ACID
Postby 302-coop on Sun Jul 03, 2011 9:19 pm
WOW way cool, just waitin for the bad news :shock:
Gerry
302-coop
Postby cords on Sun Jul 03, 2011 9:19 pm
amazing :D
cords
Postby coe1948 on Sun Jul 03, 2011 9:30 pm
When i am reconditioning motor bike carbies and fuel taps which are diecast i boil them up in water with lemon juice i even through the skins in the mix as well it brings them up like new.I must that i wait for my wife to go out first :roll: :roll: :D i am now looking for an old dish washer to use as a parts cleaner
Regards Dale[YouTube][/YouTube]
coe1948
Postby fargo on Sun Jul 03, 2011 9:32 pm
Just to add and correct me if i am wrong the Molasses method is similar the fermet reacts and turns it into cirtic acid just takes longer from what i have read and seen.
Dean
fargo
Postby barnsey on Sun Jul 03, 2011 10:00 pm
malt vinigar from woolies or coles, $2.50 for four litres, also does the same job, you just need to make sure you wash everything really good in soapy water afterwards or it keeps eating away at the metal. check parts every 12 hours, these discs came up like this after 18 hours soaking in mault vinigar, when removed you just use tap water and a dishwashing brush, then repeat washing in soapy water.
before
after
founding OZ E RODDERS member # 8 joined on Tue May 31, 2005
Visit us here > http://www.ozerodders.com/
barnsey
Postby fargo on Mon Jul 04, 2011 6:13 pm
Did think of the vinegar later but wasn't 100% sure what it would do but definatley works well will keep that in mind also
Dean
fargo
Postby 63wagon on Sat Jul 16, 2011 4:53 pm
where can i buy the citric acid crystals in 1kg bags ..woolies has small jars,i would need alot to make up a 30lt tub mix.
i have a few rusty 63 ford parts that need cleaning up .( must have been parked near a holden at some stage ,lol) :)
thanx
dave ..
63wagon
Postby fargo on Sat Jul 16, 2011 6:33 pm
Not sure where you are but i am in Adealide and got them from Gaganis Bros a bulk food store here maybe try a chemical supplier as i beleive you can buy it in 20kg bags
Dean
fargo
Postby wot179 on Sat Jul 16, 2011 6:41 pm
W.S.C.C.A.
St Marys chapter.
wot179
Postby 63wagon on Sat Jul 16, 2011 8:21 pm
thanks guys ..
im in s/e QLD .
i was hoping to find it at my local woolies /coles etc ..
ive checked a few sites (google search).but cant travel far ,.ill see what i can find .
63wagon
Postby fargo on Sun Jul 17, 2011 12:12 am
Nearly forgot the first lot i bought was from the home Brew shop quite a bit dearer at $17 kg but was close buy .
Maybe even a health food store not 100% though
Dean
fargo
Postby 63wagon on Sun Jul 17, 2011 1:30 am
ill give my local home brew shop a try ..ty ...
63wagon
Postby Blackadder on Sun Jul 17, 2011 10:34 am
Very interesting. Does this stuff only work by immersion? How would you go about doing large panels? The rear guards from my Wolseley have quite a bit of active rust on them and I'm thinking they will need something doing sooner rather than later.
Thanks for sharing a great idea!
Andrew.
"Am I jumping the gun, Baldrick, or are the words "I have a cunning plan" marching with ill-deserved confidence in the direction of this conversation?" - Mr Edmond Blackadder the Third.
Blackadder
Postby rog on Sun Jul 17, 2011 12:42 pm
Drew wrote:Very interesting. Does this stuff only work by immersion? How would you go about doing large panels? The rear guards from my Wolseley have quite a bit of active rust on them and I'm thinking they will need something doing sooner rather than later.
Andrew.
I Think phosphoric acid? Hotrod andy Used on his surface rust, seemed to do the job.. Must admit i havent tried anything myself as yet.. but need to do so soon.. roof interior, front & rear guards :lol: :lol: :lol:
rog
Next
Return to Construction
Who is online
Users browsing this forum: murray and 5 guests
