35 Ford Roadster Rear
I started an interesting job this week and thought I would share. 35 quarter panels are quite large and have a lot of detail, so I will break it up into a few pieces. The first piece is most of the vertical part from the B pillar to the top of the wheel arch. I layed out the paper template and hold it down with magnets, and mark and cut 2 parts.
I used the flattest wheel I have a 12” radius to wheel out this part.
Next I mark out the curved section which folds into the trunk, I add 1” to the edge for that fold.
I folded the trunk edge then shrunk it down in the kick shrinker.
Then I shrunk down the other side with thumbnail dies in the Pullmax.
I wheeled out the marks from the Pullmax and curved the panel with a tube on the top wheel.
I noticed I had shrunk too far in towards the top of the panel so I didn’t go so far on the second panel. (Marked in pen)
Steve's Custom Metalshaping.
0431 787 088.
http://s975.photobucket.com/albums/ae231/ima38/
https://www.facebook.com/pages/Steves-Custom-Metalshaping/1412214592364720
0431 787 088.
- blown36
Re: 35 Ford Roadster Rear
Nice work Steve, I'll be watching this one, I have some rough rear quarters I brought in from the US, probably worth saving but I'll need a few fill pieces. So far I've collected these from the states and everthing else in Australia back to the B Pillar. Rear half to complete.
Subscribed
Subscribed
Get Blown or get Blown Away
Nice work as usual Steve ,next time we venture down the big smoke id like to call in and say hey ,love to see how you make those panels up
Thanks Blown36,Monte,
Anytime your down you can drop in,doesn't take much for me to stop for a coffee (or scotch)
Cheers Steve.
Cheers Steve.
0431 787 088.
0431 787 088.
Nice work oztinbasher
This is the combination I used to define the beltline with the bead roller.
I made some plastic forming dies to finish the beltline in the Pullmax.
Did a couple of test pieces to get the right combination for the swage line around the wheel arch.
Had to get a hand from my wife Kerry to do this panel as it was a bit big to handle.
I use ½” bead roller with skateboard wheel to tip the bottom edge.
Shrunk the edge then tipped the lower flange and flattened out with a hammer and dolley.
This is the start of a reversible buck.
Cheers Steve
Cheers Steve
0431 787 088.
0431 787 088.
- ken1939
Super work so far, looking foward to seeing more. Love the buck you made. Take it you had an original to make the station from?
Hi Ken,Turns,
I had a painted and assembled car to go off which made it a bit difficult.
Cheers Steve.
Cheers Steve.
0431 787 088.
0431 787 088.
- stevenm
Sweet as work there Steve - what you can do to a pice of tin is totally beyond my skills
Steve
sometimes you blow your nose with a piece of toilet paper......... bet that piece of paper considers itself lucky
www.skmdesign.com.au
Steve
as usual a pleasure to watch your work steve
Nice seeing how it is done mate.
- ken1939
To say the least! Based on my experiences making door skin bucks at least. Lots of tense moments to be sure. Although I always wanted to try one of those profile tools they sell. Looking forward to moreoztinbasher wrote:Hi Ken,Turns,
Cheers Steve.
- compact
ditto.....nice workstevenm wrote:Sweet as work there Steve - what you can do to a pice of tin is totally beyond my skills
[img]http://www.ozerodders.com/images/oer-member.gif[/img]
"Life is not about waiting for the storms to pass...it's about learning how to dance in the rain."
Thanks Guy's,
A small update on the roadster panels, I refined the buck to fit the panel so far.
Then I clamped the panel to the buck to knock over the edge to the guard.
I shrunk down the B pillar edge to match the profile of the door.
This panel is basically finished until I start welding.
Cheers Steve.
Cheers Steve.
0431 787 088.
0431 787 088.
I didn't realise it was that simple fantastic results
