6v53 GM blower
- trackdodge
6v53 GM blower
Anyone had anything to do with these? ive done alot of google searching but there is very little info on them. i bought one on the weekend and wouldnt mind having a fiddle with it, apparantly they are what weiand and cragar blowers are designed around
- fredeuce
6/53
If it is a genuine 6V53 blower then it may not be ideal for what you want.
The traditional GM blower is the 6/71 which was fitted to an inline 6 cyl two stroke diesel. They are constructed with a substantial flange on the base which is where they bolted to the original GM block. These lend themselves to easy adaptation to small/big block V8s. This has been going on for over 50 years. It has also resulted in a significant aftermarket industry by the likes of Weiand , Cragar etc as mentioned.
The 6V53 is a small (318ci) two stroke diesel engine in V6 configuration. These blowers do not have the flange at the base but are held on by studs that engage with lugs on the side of the blower housing. Not an ideal arrangement when it come to adapting to a V8.
fredeuce
- trackdodge
- trackdodge
how about this one on the mustang - http://www.elsberg-tuning.dk/the%20cars ... %20Mustang
- trackdodge
6v53 GM blower
Not yet but one day, I have one of those backburner projects that sometimes gets attention when I get the time.
If you think you can you probably can, if you think you cant, dont bother, Henry Ford.
6v53 GM blower
Heres some more, perhaps there could be a tech link for blower identification.
- trackdodge
The Mustang has a 6-53 blower. The fin spacing is different. On second look the 32 has a "pruned" 6-71 on it.trackdodge wrote:I thought 6v-71s bolted on the side with angled bolts?enjenjo wrote:That is not a 6-53, it is a 6V-71. It's similar to a 6-71 in size, but similar to a 6-53 in mounting.trackdodge wrote:here is one fitted to a six -
- trackdodge
Re: 6v53 GM blower
neatride wrote:Heres some more, perhaps there could be a tech link for blower identification.
4-71 on the left and 6v-71 on the right.
Trackdodge - I've a complete original GM manual for these blowers. It covers all of the '53' series blowers, how to ID them, decode the numbers and more importantly dismantling and re-assembly. It's a pretty hefty book. If you'd like it then send me a PM and we'll discuss getting it to you.
Cheers Redned
Cheers Redned
- trackdodge
does anybody know this car? looks like a neat set-up http://www.hotrodfeatures.com/Feature0305.htm
- mgtstumpy
6v53 GM blower
6-53 blowers are an oil pressure feed for the bearings because they are like cam bearings instead of the standard ball bearing type on other blowers, weiand and b&m while similar have there own castings and end plates. You need to supply oil under pressure from the engine to be fed into the front or rear bearing plate and then "T"ed off to the other, and then returned to the engine after the oil has passed through all bearings. 71 and 90 series blowers after modified for gas can usually be used with a bath type lubrication up front for the gears ie no oil from the motor just contained to the front blower housingThere are a few holes on the bearing plates that you wont need so they need to be plugged. If you slow down and pause that inline blown video you will see on the left side of the blower what I mean. First point of call might be a call to mr fischer for advice.
