Mudgy's 1937 Dodge Sedan
Re: Mudgy's 1937 Dodge Sedan
Great to see you progressing well Mudgy keep at it mate.
Well, I think making dummy stuff has to stop for a while, and time to make the real deal (= shell out a few $$$)
Dreamt up a heat shield for under the fuel tank (needs to be about 80mm longer at the front though)
Got it all sitting back in, seems to look/work OK for me.
So I think I'll need to make a small left to right bolt-in rail, to hang the mufflers off... not sure yet.
any-hoo, thanks for looking.
Nice CAD work Mudgy, its all progress and making the real deal is so much easier when you know exactly what you want.
It's all part of the fun, frustration and finally the satisfaction of building our projects, keep at it mate.
Thanks Pete,
I did make one more small bit last night from all that's left of my C channel.
Postimage isn't loading, so I'll try later on today.
Nice work Mudgy. Some meticulous planning beforehand and mocking up pays dividends.
sorry mudgy but i can't help feeling that at the end of all this you are going to end up with a cardboard car sorry mate
I'm going green, mate !jailbar joe wrote:sorry mudgy but i can't help feeling that at the end of all this you are going to end up with a cardboard car sorry mate
Just extended it and make it look like ground effects!
People will think it has a race car chassis!
Thanks Frank... It's easier to see what I can and can't do if something inhabits the space... the cardboard and the corflute cost me nothing except the sticky tape. And the Ag pipe was cheap as chips.FRANK BASILE wrote:Nice work Mudgy. Some meticulous planning beforehand and mocking up pays dividends.
HAHA Marcus.... a diffuser... I'd have to go full Tokyo drift/widebody to pull that look offGoJeep wrote:Just extended it and make it look like ground effects!
Postimage is working today..
I hope I can use this. Otherwise it was an excercise in wasting a disc.
- Beelzeboss
Looks good!
My build log:
http://www.ozrodders.com/forum/viewtopi ... =6&t=63709
A Willys MB Jeep with modern(ish) Toyota components
Sweet Mudgy even if you've wasted a disc you did it with style mate.
Angle grinder cut shaping I found can be eliminated by using a Plasma cutter. Purchased a cheapy unit some time back from Aldi. cuts up to 10mm metal. Made things quicker. Especially when it got to chassis boxing plate.
- Beelzeboss
I agree Frank, the plasma cutter was a godsend when it came to making my chassis boxing plates, I can't even imagine how many cutting discs I would have used doing thatFRANK BASILE wrote:Angle grinder cut shaping I found can be eliminated by using a Plasma cutter. Purchased a cheapy unit some time back from Aldi. cuts up to 10mm metal. Made things quicker. Especially when it got to chassis boxing plate.
My build log:
A jigsaw with a decent metal blade works well for this sort of thing also .
