Team Lone Star - All Thriller, No Filler
Re: Team Lone Star - All Thriller, No Filler
. . . brilliant . . . got my attention
Thanks for posting guys . . .
Maffra
Just to add to what others have already said, a BIG thank you to both of you. This is really the type of thread that gets my attention. Very clean work with a nice execution of the assembling. Have you repaired the door structures yet?
Michael
Michael
Tony, I look forward to seeing you again, you are always welcome.
Michael, The doors are the next area that will be worked on.
Stuart Smith
Sheetmetal Whisperer
It just works...
It's easy to make simple look complex but it's difficult to make complex look simple
It just works...
- Vonfat
- Location: Mornington Peninsula. The hot rod capital of Victoria!
Great post Turns. Thanks
Anything older and noisier than me is fine.......except women!!!!
"Do unto others, before they do unto you".....J.R Ewing
- cripple-pete
Great job Stuart,
good to see some talent, the detail in the back is real nice..
What happened with the roadster you were getting parts for ?..
Looking forward to the next installment....Thanks..
Pete..
Pete..
Hi Pete, How is the North Coast...The `35 Roadster hasn't seen much progress lately, however, I did use the cowl to mock up and use for a guide for what the Ute lower cowl needed to look like
Stuart Smith
It just works...
It just works...
Thanks for the quick reply. Obviously the door was in good enough shape to allow you to set the gap between the trailing edge of the door and the front of the 1/4 panel before repair.
Thanks again
Michael
Thanks again
Michael
- cripple-pete
You wouldn't like it at the moment, way to wet to do anything...
I really like the infills in the back, looks very solid, you should have taken mine to build.......
Keep posting, we were getting bored.......
Pete....
Pete....
wow... these are the type of threads that inspire people to have a go,and that nothing is beyond it.......... and me being a glutton for punishment will have a go
keep the info rolling.....really great stuff
- stevenm
That is bloody unreal..... totally take my hat of guys.....
Steve
sometimes you blow your nose with a piece of toilet paper......... bet that piece of paper considers itself lucky
www.skmdesign.com.au
Steve
- hot rod andy
awesome guys, some really nice work going on there. i take my hat off to you
keep that info and pics coming turns........well done
Growing old is inevitable..............Growing up is optional............
oz-e-rodder member no 160
Pete,cripple-pete wrote:You wouldn't like it at the moment, way to wet to do anything...
Pete....
were you speaking of the build that went to Yamba, how are you progressing with that, I haven't seen it...
PS, If you are stuck between a rock and a hard place with it, give me a call, I did get a subliminal twitch that you were not getting progress...
Stuart Smith
It just works...
It just works...
Wow
What a great response to the first 'Team Lone Star' thread
I am very glad that this has been a worthwhile exercise and been well recieved. As you can see it is far easier for Stuart to contribute further content to an already existing thread.
I started this thread with 'and so it begins' and yes it has. I will continue to grow this thread as often as I can as this ute build is the tip of the iceberg in regard to worthy content to post. As discussed I will start other threads that are more specific to topics eg Pullmax, English Wheel, sand bag, hammers and so on. Cords is a gun welder, as is Stuart and a thread dedicated to different types of welding could be valid. And on it will go.........
Any suggestions on content that relates to someone's build they are stuck with??
Thanks Guys excellent material & content! With the filler pieces in the rear, it looks like you spot welded them to the tube? Any more info Please?
rog wrote:Thanks Guys excellent material & content! With the filler pieces in the rear, it looks like you spot welded them to the tube? Any more info Please?
Hi Rog,
The YouTube link above shows the spot weld process, it is an inverter machine that has the capacity to weld different thicknesses to correctly prepared tube,
The join is sprayed with a zinc rich weld through primer before welding, then the cavity is filled with an anti flutter foam to avoid crap/ moisture getting in there.
Stuart Smith
It just works...
It just works...
