slimfromnz wrote: Cool thanks Stuart. One question, why do you have a residual pressure valve on the front system and an adjustable proportioning valve on the rear system?
Royden, The master cylinder is under the floor, hence the 2 Lbs. residual pressure valves( I also have one in the rear line). In theory, gravity pulls the fluid back to the master cylinder and retracts the caliper/wheel cylinder pistons, which increases the pedal travel for the first application of the brakes.
The residual pressure valve is just a tool to balance brake bias, all of my builds incorporate one of these, the workshop truck has all new components, incl. factory proportioning valve, however, it would regularly lock the rear wheels untill I fitted an adjustable proportioning valve to trim the bias.
redsx wrote:So in the pic of the master cyl. is that a brake light switch in the banjo fitting going into the master cylinder as there is already a brake fail switch in the master. I Like the job of coiling the lines but is it really necessary in this situation. Also using an adjustable proportion valve wouldn't it have to be locked?
Correct, that is the brake light switch.
Coiling the lines reduces the ammount of flex transmitted to the flare where the flare nut secures it. Flex will fatigue the line right at the flare, and that is where they will snap through. Even though the master cyl. and the lines are clamped, there is some movement, just get someone to push the brake pedal hard in whatever you drive, and watch the firewall flex.
The prop. valve has a lock nut on the adjusting stem to avoid tampering
