Well, I rearranged the shop (shed) and will be pulling the front end out of the jag soon, to put under my 54, so I thought I would start a journal here of the build, so I can share all my mistakes and screw-ups with the world. A friend is going to give me some hands-on training to teach me how to post photos.
Re: 54 Hudson coupe
I just read that post.... That was a long-arse sentence. I'll have to use more punctuation.
Re: 54 Hudson coupe
Re: 54 Hudson coupe
Re: 54 Hudson coupe
That'll be a cool looking car when it's done. What powertrain will it be running? Pics look good. P.S. Bit of shed envy.
Re: 54 Hudson coupe
olfrt wrote:That'll be a cool looking car when it's done. What powertrain will it be running? Pics look good. P.S. Bit of shed envy.
Engine will be a big block Ford with a E4OD, and 8.8" Ford rear with 3.55 LSD.
- steve the ford guy
Re: 54 Hudson coupe
The front suspension looks identical to early fifties Ford
Last edited by steve the ford guy on Thu Aug 15, 2019 6:33 pm, edited 1 time in total.
Re: 54 Hudson coupe
It looks like a good project so thank you for sharing.
We all make enough mistakes to teach each other how to do things right so don't hold back on the good as well
Re: 54 Hudson coupe
Sweet looking project Dany keep up up to date please.
Re: 54 Hudson coupe
Subscribed,,....lookin forward to seeing more of your Hudson build
Al.
69 Camaro Z28 Clone....
Re: 54 Hudson coupe
Looks like a Jag will fit in there nicely, looking forward to watching your progress.
Re: 54 Hudson coupe
I ordered and received my upper shock mounts from Top Rods (thank you Peter). I’m getting everything cleaned up and painted and ready for reassembly. I noticed, when mocking up the shock mounts, that if I line up the inner edge of the upper bracket, with the inner edge of the lower bracket, the upper bracket is not centered on the crossmember. (It’s off center about 1/4”) My gut says center it and let the rubber mounts on the shocks take care of the misalignment... What do you advise?
Re: 54 Hudson coupe
Hey Dany, if you look at page 4 of my build, it shows the brackets and the KYB shocks that suit.
I had the same issue, I tacked the 3 pieces together then mounted the new shocks with the suspension at the "loaded height" and allowed the mountings to settle in their natural position. I then checked for clearance through the full suspension travel range, then tacked them in after a little re-adjustment. I did this after renewing the bushes in the upper and lower control arms and without the springs in of course.
Re: 54 Hudson coupe
Thanks Newbee. I went back and looked at your build photos, and bought the shocks on my way home from work. I will be centering the shocks within the upper control arm, and welding the brackets accordingly.
- choco
- Location: Jerrabomberra, NSW, where, on a crisp winter's morning you can hear the Chevs rusting.
Re: 54 Hudson coupe
Excellent. More Hudsons, please!
Ph:0412 883 235
Ph:0412 883 235
