Mustang HO engine
Mustang HO engine
Me again ,the other option I have for an engine is a HO 5 ltr mustang engine with a ADO non computer 4 speed auto ,I am thinking I could convert this back to carb as it has no computer with it or I could buy a computer and loom for it and run the EFI only need to put a high pressure fuel pump in the tank and return line ,,if I go carb what dizzy can I use ,seems that some people have used the original and it works ok if you just hook it up to the ignition
Re: Mustang HO engine
Hi Monte
Can I ask ?
What is it going In ?
Are you planning on 3 Rods at the Nationals in your back yard ?
Not much time left ...
Can I ask ?
Only 1.5 rods at the moment Greg but I have to decide which engine and auto to put in it
- Big G
I fitted an OZ fuel injected 302w to Black Bess and ran a carby & manifold, I used the original dizzy. Ran great, didn't even touch the timing. Mated a rebuilt c6 auto to it, had no probs at all
Founding Oz E Rodder Member
I've lost the Plot
One day I will find it !
I've lost the Plot
Did you have to run a coil or just plug it into power ,thanks mateBig G wrote:I fitted an OZ fuel injected 302w to Black Bess and ran a carby & manifold, I used the original dizzy. Ran great, didn't even touch the timing. Mated a rebuilt c6 auto to it, had no probs at all
We fitted a 302 AU XR8 EFI motor n computer controlled BTR Auto 4 speed box to my F100.
Bought an XR8 used the ECM , engine harness..and a J3 Chip to run it,..used everything fron the radiator n fans back,...including engine n box
Easy with a J3 Chip.. Chip defeated security ...I used a XG Falcon Ute tank with intank pump...plumbed a fuel line n return
BTR runs just needs a good speed signal,...check with Chocko ...hes up to speed on all thsi stuff,...But Chip guy told me to make sure the ECM and the harness all are the same,.....little bugs will creep into things
Al.
64 Ford F100 SWB Patina Pickup
69 Camaro Z28 Clone....
- Big G
Used the standard coil.monte wrote:Did you have to run a coil or just plug it into power ,thanks mateBig G wrote:I fitted an OZ fuel injected 302w to Black Bess and ran a carby & manifold, I used the original dizzy. Ran great, didn't even touch the timing. Mated a rebuilt c6 auto to it, had no probs at all
I've lost the Plot
I've lost the Plot
thanks mate
