Finally gettin a start on the rod(rollin n channelled)
- 302-coop
Re: Finally gettin a start on the rod(rollin n channelled)
Anyone know if bearclaw latches are accepted in South Australia
- 302-coop
Can anyone tell me how to remove the windscreen actuator from a 37 ford pickup dash?
- 302-coop
Anyone?302-coop wrote:Can anyone tell me how to remove the windscreen actuator from a 37 ford pickup dash?
Hey Gerry is it similar to 36 ford that crank out with a handle in the middle part of the dash?
- 302-coop
Yep it is mate i just cant see how the handle comes off to allow separationChrisso wrote:Hey Gerry is it similar to 36 ford that crank out with a handle in the middle part of the dash?
It should have a screw through the middle?
- 302-coop
In the middle of the handle at the front? Or the middle of the back thru the shaft?Chrisso wrote:It should have a screw through the middle?
- 302-coop
Nah mate no screw in it
Anything on the outside like a grub screw maybe?
- 302-coop
Hey all, yes still here and been doing a bit, no no no i havnt given up or sold it. Just wondering if anyone knows if you can get a repro shaft that goes into the windscreen actuator for mid 30's fords. I left mine in citric bath a bit long and the spline is all but gone. Have done some interweb searches but as not sure of its actual part name cant seem to find one
Any leads appreciated.
Hey Gerry, is this any good to you? http://lbcunited.com/earlyford2/product ... 384f404ab0
- 302-coop
Almost Chrisso, the pickup unit has a shaft about 4" long that runs in to the same type of actuator.Chrisso wrote:Hey Gerry, is this any good to you? http://lbcunited.com/earlyford2/product ... 384f404ab0
Thanks anyway
Gerry could you use a window regulator spline and graft it on??
- 302-coop
Yeah mate have looked at those options, just thought if i could get a replacement it might save a bunch of fiddly work.Chrisso wrote:Gerry could you use a window regulator spline and graft it on??
G
