Rust Removal and Prep CITRIC ACID
Re: Rust Removal and Prep CITRIC ACID
Thanks for the info that will save me a lot of work that is what I have done after the molasses and it holds up for a long time haven't used citric before
Ditto here . . . thanks Joe, thanks Chris much appreciated guyspilot48 wrote:Thanks for the info that will save me a lot of work that is what I have done after the molasses and it holds up for a long time haven't used citric before
Thanks and regards
Maffra
Hi,
I have used citric acid to remove the rust from my Model A Ford panels with great results, but I have a question about the fuel tank, which is in good condition but does have a lot of surface rust that needs treating. However I am concerned about where the fuel cap is and other parts that seem to be soldered (or some other method). If I immerse the tank into the citric acid bath, will the citric affect these areas.
Appreciate any advice.
Thanks and regards
Thanks and regards
Maffra
- steve the ford guy
Hi Maffra, this page has info that should help.
https://manual.museum.wa.gov.au/book/export/html/33
That is a great article and answers my question. Thank you, much appreciatedsteve the ford guy wrote:Hi Maffra, this page has info that should help.
Don't think I will be immersing the tank in a citric solution and I will use some other process to deal with the surface rust.
Thanks and regards
Maffra
