460 into a 32 roadster
Gday im building a 32 roadster with a 460 bigblock and need some advice with the exhaust. Its real tight between the block and chassis rail but still want to run the headers through here so i can still fit a full hood and side covers. Im thinking of fitting some cast iron manifolds of an F truck and coating them but would prefer some custom made headers, does any body know of who can make some.
- woody28A
Re: 460 into a 32 roadster
Hi "wayno" and welcome to the forum. Might be a good idea to let people know what state you are from, so they can provide info.
My crystal ball says WA . .
Frank.
Frank.
- ekdave
now how did u come up the that
Frank ?>
wayno
Frank ?>
wayno
1962 Ek Holden .. V6
1942 chev pickup truck under construction
1946 chev 3/4 ton pickup next project
is it the fomoco BBs that have mirrored header flange bolt pattern?
if so, you might be able to run the f truck headers in reverse, ie LH to RH and vice versa.
then a small u pipe on the end and run the exhaust under the headers and where it needs to go.
my favourite colour is chrome.
- woody28A
Pretty sure the location info wasn't in the original post. Maybe it was edited, maybe I just missed it.FRANK BASILE wrote:My crystal ball says WA . .
Frank.
- slimfromnz
Have you lost your glasses Tonywoody28A wrote:Pretty sure the location info wasn't in the original post. Maybe it was edited, maybe I just missed it.FRANK BASILE wrote:My crystal ball says WA . .
Frank.
Have to get some back
Royden Hardcastle
1938 Chev Sedan LS3 power
1928 Dodge Senior Six BBBuick power
- 34 pickup
dom at prestige exhaust in malaga makes real nice pipes , not cheap thou
- fredeuce
As you are running a full bonnet then perhaps a show standard finish is not what you are looking for. That said you could have a go at making them yourself . Start with some header plates, which good exhaust shops can supply , a pair of collectors, some 90 deg bends and perhaps some donuts. You will also need a band saw and an oxy set. Do your arithmetic on costs and see what is going to work best for you.
fredeuce
- mgtstumpy
Around 1980 well known rodder Les LAWRY stuffed 429CJ into a 30 sedan, all under the hood. I think he ran 2" primary pipes.
- woody28A
I've got schooner glasses, will they do??? Sometimes things look clearer through the bottom of a glass.slimfromnz wrote: Have you lost your glasses Tony
- bbwillys
Just sent you a PM
Your not the first or the last person to do it.
There is a blown 32 roadster with 460 (black with single orange GT stripe) (VIC)
Yellow turtle deck T bucket with a NA 460 (VIC)
Orange 32 ford Tudor NA 460 with tunnel ram (NSW)
A 460 is about 2in wider then a Cleveland.
- JohnL
This is what the Ide's A coupe on 32 rails used to look like with headers inside the rails- tight! It now has zoomies.
Did it get finished and on the road?
- ken1939
I have a 429 in a 32 Roadster that I am trying to finish. I had to make my own headers to fit the way I wanted them to. I had to recess the engine about 4 to 6 inches to get proper clearance and enable me to keep the stock look of the car. I opted for no bonnet as I am able to do so here. Its a highboy so no fenders either, but I wanted to keep the exhaust within the frame rails as well maintain a good scrub line. I recon there are tube headers out there that could be a start. I made mine similar to the stock ones but used pre polished stainless tube.
