Here's something......
- 35coupe
Re: Here's something......
That's a lot of motorway!
Did you see the rod at around 4 and a half minutes?
Here's something.. shades of the old twin engine "Bustle Bomb".. if you are browsing the newsagents and see the Nov - Dec issue of Vintage Trucks & Commercials Magazine ( Australian).. on p.26 for flathead fans.. 1939/40 aftermarket produced twin engine '39 & 40's COE Henry's by Grico & Thorco.. pulling 60 foot trailers. For those "other" people, there's also a small plan view of an Octopus chassis twin chev 6 by Eisenhauer
'36, or is it ?, Ford pickup ( one day..) an' a 'A' hangin' in the rafters ( or was.. the rope broke )
Here's a few more shots re the visit to the private car collection / museum, mentioned in Col's "42 years thread".. a poor image, no light, of the flat 6 in the rear of the Tucker.. another that shows how close the Tucker got to the Cord when it shot backwards in the wrong gear.. reverse !.. real heart in mouth stuff.. the tyre marks are from when he took off forward.. then just some general shots of this truly superb car.. first padded dash, seat belts etc.. I never ever thought I would get to see one in the flesh.. so appreciative of the opportunity to do so.. Thanks Col
Hope this works.. if so may have finally learnt how to post from fb album as trying to use photobucket was a disaster
Seems to have worked fine, thank you for sharing.
Thanks for posting more on the Tucker. The engine was originally designed for helicopters I remember hearing one time?
Marcus.. there is a bit here re the Tucker Engine's aviation origins http://theoldmotor.com/?p=31273
I got 100 percent.stillhavinfun wrote:Thanks for posting that Link.jailbar joe wrote:just pinched this of the hamb....I got 79% or 44 out of 56
http://api.viglink.com/api/click?format ... ailfins%2F
I got the same as you, but 3 or 4 were pure guesses.
jailbar joe wrote:okay boys and girls....time for another test....hope you have been studying
I got 90% or 38 out of 42
http://api.viglink.com/api/click?format ... ckup-id%2F
I got 98 percent. The only one I missed is the 60 Studebaker, the Navy models were the only ones to use that cab, all the others used the new cab that came out in 1960. Trick question.
Thank you for that.mgyxjc wrote:Marcus.. there is a bit here re the Tucker Engine's aviation origins http://theoldmotor.com/?p=31273
Tuckers & Cords.. more re the Private Collection visited last weekend and as posted here http://www.ozrodders.com/forum/viewtopi ... &start=705 and by Col at.. http://www.ozrodders.com/forum/viewtopi ... start=5385 This lot is what.. A Cavalcade of Cords... Functional side exhausts and wind up "pop up" headlights.. in 1936/37 ! The Blue Cord, as built for Amelia Earhart, painted in ‘Eleanor’ Blue.. named for the wife of Franklin Delano Roosevelt, the 32nd President of the U.S... what a great paint choice for a ‘stang Check out the dash.. that’s for sure a comprehensive set of instruments... the little chrome ‘side window like’ winder at the far right of the dash.. there is one on each side.. they are for the Pop Up Headlights Look past, the side exit exhaust, the nickel horn trumpet and water pipe, and nestled in the Vee, a McCulloch supercharger The Cord’s Lycoming is like my Cadillac flathead, and the UK origin Standard (later Standard Vanguard - Triumph), V8’s, with their exhausts coming out of the valley rather than the sides as with Ford’s flathead... dig the neat head with it’s ‘Star’ cast web Differentiating the Lycoming completely though, from the Cadillac, Standard or Ford flatheads is the canted valve arrangement, in deep pockets with a cast in ‘Relief’ across to the bore, necessitating the pop up wedge on the pistons.. it all seemed to have worked though, with the hp ratings Cord parts car..! .. and a couple showing the half shaft and CV carier on the front trailing arm.. and a last Cord.. fwd circa 1929, 301 cu in straight 8 sedan superb paint Miller Fords & Cords aside, it was a few years, decades, before Detroit would try a big V8 front wheel drive sedan.. but when they did.. it looked a ripper, and they are in the Collection as well..425cubes / 385 hp 1966 Toronado.. and a later model
Along the lines of "Here's something...' different.. here’s a Big Flathead.
A 464 cu.in. Flathead V8, making 90hp, of modular construction, alloy crankcase with cast iron cylinder blocks & heads atop. Exhaust ports in the valley, with inlet, like the smaller 322/346 LaSalle and Cadillac flatheads.. you've got to bet it would have a deeeeep rumbling note.
It's a 1921 Daniels Speedster D-19. Made in Pennsylvania, just 100 built from 1915 through 1924 & this particular body style was called the Daniels ‘Submarine Speedster’.
1st pic.. looks like just any old flathead Ford paddock bomb chassis stripped down.. in the back.. looks like a massive piece of ballast bolted to the chassis, with an eye bolt in the top..
and a few of the engine..
Now that is one beautiful automobile.
- Mopar Mick
Wow, how would you like to stumble on something like that.
Looked to be in very good condition.
Thanks for posting this on here Chris.
Mick.
Mick.
