Calculating pedal ratio
- spark
Using this as a guide, the pedal length ( X) = 4.1 x Y,
so the length of the pedal is 4.1 times the length of the Y part (pivot point to pushrod)
Pedal length X = 24.6 cm pivot/pushrod Y = 6cm
so- 24.6 divided by 6 = 4.1
Have I got it right?
[img][img]http://img.photobucket.com/albums/v199/ ... dalset.jpg[/img][/img]
Danger- man with a dry sense of Humor that lives near the sea.
- chris spokes
Hey spark.....I just went to post a reply and my comp froze Im gonna burn it.......anyway, Ive always looked at it this way, X is 4 times as long as Y........or cut X into 4 equal lengths and one of those lengths is the measurement for Y....4:1, 4 parts sand, 1 part cement ...Im a bit forest gump like at times ...Bert
Hillbillys from outer space...................
- spark
- toprodz
Hey Spark I have been looking at your picture and I think that you are pretty close to what is needed. If I get a chance in the next couple of days I will measure some of the pedal sets I have got here and report back to you what I find
Yeah Bert stay on topic and stay away from those cake recipes that you mentioned
- spark
I saw it once on bob the builder..... He should know..............Bertspark wrote:Gee Bert, if we’re talking concrete its 3-2-1 three gravel, two sand, one cement.
Mortar 6-1- six sand, one cement. (add a little lime)
Try and stay on topic will ya!
Thanks guys just checking my thinking.
you still going with the underdash setup spark? got any pics?......manual or auto?..........
- spark
Yes, auto – HiAce or make one. Spotted a under dash set up in ASR $440 + booster + master.Bertieboy wrote:[you still going with the underdash setup spark? got any pics?......manual or auto?..........
nzsimon sent me a pic of his set up-
[img][img]http://img.photobucket.com/albums/v199/ ... ooster.jpg[/img]
All I need to do is to find someone with a lathe.
[/img]
[img][img]http://img.photobucket.com/albums/v199/sparkm/crank.jpg[/img]
looki looki- http://www.kugelkomponents.com/products ... ystem.html
http://www.kugelkomponents.com/products ... stem2.html
and - http://www.ecihotrodbrakes.com/master_c ... stems.html
(bottom of the page)
[/img]
- spark
- chris spokes
I was looking at the using the same setup but I dont know if I will or not, you doing it for extra space? geeeez its pretty busy lookin........I think I will stick to underfloor.......lathe? no worries spark......its still lying on the floor not set up , but thats cool, just let me know what ya want and when, its old and crusty but will still turn up basic stuff...oh, and the lathe is too ...............cheers, Bert
- spark
The problem I have with under the floor set up is it will take up the space right were the muffler needs to be.
I had planed to run the exhaust from the headers to a muffler and have it exit in front of the rear wheel. Once the pipe is in position, I will cut a hole in the back of my side pipe and poke the working exhaust though so the fumes come out of the end of the side pipes.
I could run pipes and muffler lower but it would be highly visible. I was also toying with the idea of a belly pan. The back of the cab is channelled about 6inches- enough room to hide the muffler.
As usual one problem solved creates another, the heater will have to go way over on the passenger side. I spent last night mocking up a under the dash set up (made pedal, bell crank and a booster out of craft wood and 7 inch tin). It all fits up there; the pedal is in a good position.
- blown32
One other thing to remeber is your gauges, A mate of mine started setting his under dash booster up in a 32, went and bought a set of gauges and then realised that the gauges were too deep and would hit the booster. just something to keep in mind.
At least I have learnt by his misfortune, and can try and get around it in a different way.
John.
[img]http://i732.photobucket.com/albums/ww326/blown32/beers1.gif[/img]
www.marshrodders.com
John.
