Father Son project
- robtus
Re: Father Son project
Nice project, glad to see the young fella getting involved too. Looks like a mint body considering the years.
- spoggie
Cool car. Are theses strippers caustic? A good dose of citric acid in ya water nuetralises alkakine caustic soda based stuff. Then water rinse.
- rattyrod
Hi Spoggie, i would say they are because if it gets on your skin it burns till you wash it off. The body has been stripped for about 3-4 weeks now and true to the soda blasters advice the bare steel has not got any surface rust what so ever. The body was wiped off with a rag with a small amount of petrol on it and now has some old bed sheets over the top , should get blasted over Christmas
- rattyrod
In between fixing my other cars we also managed to get a little bit of work done to the diff on the valiant.
all new self adjusting brakes
new brake lines and fittings
Pete that dare I say that is a thing of beauty, a great job mate the old girl is coming along, even if the other machines in your fleet are giving you a small amount of grief.
- rattyrod
We took the S out for a bit of a spin in the warm weather the other day .I must say the fuel economy was excellent ,didn't use a drop of petrol or oil , also the air con and air ride suspension worked a treat
and off to the blasters we go
We also bought a $20 air dye grinder and carbide reamer and started work on some port cleaning and matching
You guys are making good progress, keep it up
Great progress.... how much fun is it cleaning up those tiny little shitty splinters that come off the spinning burr???
A blasting session will make the shell real beaut mate.
Nice progress fellas, that port matching will give the slant 6 a little more HP. I know I am premature Ratty or so my wife says what colour are you going to paint the S?
- rattyrod
Hi Chrisso .We already have one black car and vowed never to have another as they are too hard to keep clean and body work has to be pretty good . So black it is , but only because it used to be factory black (why couldn't it have been white ) .As for the porting , for $60 for the grinder and tip it might give me a few extra horses , if not then at least we have another tool in the collection . Will give the head the same treatment when the engine gets pulled apart. Thanks everyone for looking in and encouraging words .
I went to town on my factory 2BBL slant manifold like that, opened the ports, de-burred the outside, cut the heat riser pimples off and even drilled the webbing between the runners to try n lose some weight and gain economy. Sold it all before it was fitted so I have no idea how it went
- robtus
I like the naked body !!!!King Willy wrote:I went to town on my factory 2BBL slant manifold like that, opened the ports, de-burred the outside, cut the heat riser pimples off and even drilled the webbing between the runners to try n lose some weight and gain economy. Sold it all before it was fitted so I have no idea how it went
That porting makes for extra torque and fuel economy, especially if you can fit some upsized intake valves. Idles smoother too. When I was a lad I got the job of porting all the local petrol heads cars, that and a cam was all it took to make us THINK they went faster !!!!!
- rattyrod
Car is back from the soda blaster , or should that be hole maker ,and is all sealed up and one color for now. It has created a bit more work especially in the boot floor area but nothing that we cannot over come. Jet and our mate Adam got busy on the gearbox dismantle and we found a few damaged teeth on the cluster gear at 1st and reverse and also on the main reverse gear . The search has commenced on some locally sourced gears and if that proves futile then we will buy some from USA. We also got our wheels back from truing up ,blasting and powder coating ,and gave the starter motor a going over
Great to see a Dad and his boy hard at it, you are a very lucky man Ratty and so is Jet. I know a few blokes up here that are into S and R series and Vals in general so I will see what I can come up with mate and PM you if I am successful? The starer looks brand new bud and the body is in good nick considering the age of the car mate, shouldn't take too much work to be a really top looking ride. Can't wait for more progress pics
