Jag front end commodore disc conversion
Hey guys wondering if anyone has changed front discs on a s3 jag front over to commodore brakes? Is there anyone who makes a conversion kit? Or is it a simple swap? Thanks
who said fat is no good? on the right type of body it is.
- roguerunner
Re: Jag front end commodore disc conversion
Um I changed my XJ6 front end to Ford Discs easily as they have same Wheel Bearings and the Stud Axle just needed machining to fit the Ford Disc on it, the Stud Axle is Bolted to the front end and is easy to remove it.
Oz E Rodder member #134, ASRF member #17746,
Australian Motoring Enthusiasts Party member #1964
http://plymouthroguerunner.weebly.com
Why would you bother. They are 4 piston calipers already and stop very well
- Grazza
By chance can you remember how long was the sleeve the seal runs on was in your conversion? I've done the same but can't decide on the correct length of this sleeve.roguerunner wrote:Um I changed my XJ6 front end to Ford Discs easily as they have same Wheel Bearings and the Stud Axle just needed machining to fit the Ford Disc on it, the Stud Axle is Bolted to the front end and is easy to remove it.
Graeme
to disagree with my opinion.
"Within 5mm is Close Enough"
- roguerunner
Mm sadly no Mate...Grazza wrote:By chance can you remember how long was the sleeve the seal runs on was in your conversion? I've done the same but can't decide on the correct length of this sleeve.roguerunner wrote:Um I changed my XJ6 front end to Ford Discs easily as they have same Wheel Bearings and the Stud Axle just needed machining to fit the Ford Disc on it, the Stud Axle is Bolted to the front end and is easy to remove it.
