T700 info needed
- 36 roadster
T700 info needed
On top of an early ('94 Statesman) T700 there is a small (3/16" maybe) tube sticking out, pointing backwards. Where does this go/lead to? Also, there is a round electrical connector on the RHS, with several pins. (Not the one on the extension housing) . Does anyone have a wiring diagram for this?
Does this box use a vacuum modulator?
.....insert witty comment here.....
Re: T700 info needed
For 94 I would say that the box may still be 4L60[ updated T700] . Similar to the unit in my 93 VP Commodore Anyway the tube is a breather . No vac modulator , trans is cable . The socket would be for the Torque Converter Clutch solenoid . If your vehicle is a 94 it most likely will have gone to the 4L60E box that is electronically controlled and that socket goes to a trans control module .
- 36 roadster
So pre 94 would be the 'Non electronic" boxes? I don't want the trans with the external control box. When you say it is a cable type, is that the kickdown which is operated by the cable? If so, where does it go in?
Hi,
My 1991 VN box has the kick-down cable going in the right side, behind where the oil lines attach, cable goes down into the top surface of the casting that lives over the pan.
I'll take a few pics
*edit* here you go. But this is a 1991 trans.
the vn vp v6 & v8 boxes run a cable up to the throttle body alot easer to setup . you can get a control box for the electronic type . that is what i have been told some one on here might know where to get them from
The cable on the right side of the trans is a TV[throttle valve] cable, not a kick down. It controls internal pressures, and if not connected properly can burn up the trans in a mile or less. Do lots of research on this as the geometry, throttle angle and travel are all important.
VN Commodore T700 .36 roadster wrote:So pre 94 would be the 'Non electronic" boxes? I don't want the trans with the external control box. When you say it is a cable type, is that the kickdown which is operated by the cable? If so, where does it go in?
VP Commodore 4L60 .
VR Commodore and It's upmarket variant was the first full electronic . 4L60E . As explained , the TV cable adjustment is critical for all . Not hard to do .
The 4L60 appears to be an upgraded or improved T700 .
There is a publication that covers these three boxes with rebuild ,interchange of parts and upgrades . "GM Automatic overdrive Transmission" Builder's and Swappers Guide" . # SA 140 under the SA" performance how" series .
Try Graffiti publications for it.
What he said, just ask me how I know.enjenjo wrote:The cable on the right side of the trans is a TV[throttle valve] cable, not a kick down. It controls internal pressures, and if not connected properly can burn up the trans in a mile or less. Do lots of research on this as the geometry, throttle angle and travel are all important.
Proud Oz-E-Rodders member
- 36 roadster
The 4 pin socket (behind the shift lever) on the LHS is for....?
The lock up converter.36 roadster wrote:The 4 pin socket (behind the shift lever) on the LHS is for....?
- 36 roadster
So this is a 12v solenoid which is activated to go into overdrive? Is that actuated in the stock car by the O/D switch on the shifter or console? (I haven't owned anything newer than a powerglide, so this is the first O/D trans I will muck around with)
No it is just to supply 12v to the lock up in the converter
By supplying 12 volts to pin 4 on the connector, and a minor rewire of the internal solenoids, you can set it up to lock only in 4th gear.32coupe wrote:No it is just to supply 12v to the lock up in the converter
http://purplesagetradingpost.com/sumner ... 0R4p1.html
This site has a bunch of good info on setting up a 700R4/4L60. The lock up info using the internal pressure switch is on the second page.
- woody28A
Thanks for posting that "enjenjo". That article looks to have some really good info.
I'll second that website, I got a lot of good info from there when I was installing my T700.
