EL Falcon engine
Re: EL Falcon engine
Ford Barra Coversion & Disscussion Group , search for a member called Tim Evarettz . He can help you out with a loom
There was one of those for $200 second hand, in Geelong recently.rx4ord wrote:Is this what you are talking about Mont https://www.google.com.au/search?rlz=1C ... vydYqHjvaM:
I don't know Ford stuff at all but do love Chevy motors
aussiespeed in Adelaide do 4bbl,2bbl and I've seen weber(x3)and su manifolds for them. Also blower manifolds too
I fabricated a manifold for a cross flow 250 back in the 80s,we used a Holley 465 4 barrel,the car was quick and very drivable.
- Meeksie
I'd like to know about the reprogramming as well. Also have you had to do much with the sump to clear in the Cortina?van460 wrote:The efi wiring side of things is very easy
Im currently in the process of fitting an FG xr6 engine and zf 6 speed auto into my sons cortina
Ive had the fg wiring harness modified to suit and the factory ecu reprogramed all up cost was $380
- van460
Fg sump works in a Cortina, still need to give it a slight chop above the steering rack or you can drop the rackMeeksie wrote:I'd like to know about the reprogramming as well. Also have you had to do much with the sump to clear in the Cortina?van460 wrote:The efi wiring side of things is very easy
Crossflow mounts fit the barra with some minor mods
Will PM details on pcm programing
Bloody hell Mont I saw a ripper motor today!
I would love to have one of these. In a old bloody Falcan
Couldn't work out what gearbox but he still had 3 pedals and the old gearlever on the column.
Tricky bugger.
Tricky bugger.
Thats a BARRA engine Dave .I think it was the best engine ever made in this country ,not hard to get 1000 hp out of them ,looks like it has carbs or some sort of injection
I wonder if they are something like these .... https://racemagazine.com.au/editorial/a ... hidden-efi
I think you could be on the money Mudgy
How and where do they measure air flow ?
I am guessing they would have a mafless tune in computer, same as I am doing with the LS motor in my A ModelGreg N Smith wrote:How and where do they measure air flow ?
- van460
whats the go with the 3.0 on the coil cover
