You can get an old one RWC / registered without seat belts in Vic ,if it pre dates 1964 from memory . From then on the vehicles have the anchor mounts if I am not mistaken . Someone can correct me . And of course if you modify the vehicle to the extent it needs a VASS then belts are mandated .
Also a quick read of the link supplied by Harv. Simply refers to the buckle requirement "quick release" . Reading more there is reference to all sorts of jargon on approval numbers etc . Mention of an international standard with a circled "E" and a number representing a country . Gets back to what is on the labels of the newer vehicles we are importing . I have a suspicion that any approved belt goes now, and the exclusive AU standard has been by passed in the "global scheme" I cannot imagine a requirement for someone churning out vehicles to put "special belts " in those destined for Australia. Is it the stitching ,the webbing material , or the buckle ? . I bet the webbing is no longer made here like everything else . I will check my boxed up new "Klippan " belts from Bursons tomorrow to see where made and what numbers they have.
I just went out and tried the Mustang . Simple one or two fingers flips the buckle and release . No slower than pressing an orange or red button
Engineered seat belts with stainless buckles?
Re: Engineered seat belts with stainless buckles?
Go around to the nearest aircraft maintenance workshop, they usually got boxs of old 3 point single shoulder seat belts that were removed when an aircraft gets updated to retractable 4 point belts. For a six pack of beer they should be able to find a shiny set.Mopar Mick wrote:I want a set of chrome aircraft type (lift up) seat belts.
Is this possible using webbing with the correct tags made by an Australian manufacturer/distributor
Mick.
If doing a google, the brand is "Amsafe"
The world's most viewed site on global warming and climate change... http://wattsupwiththat.com/
Australia’s most viewed site on global warming... http://joannenova.com.au
- johnonetrillion
You may be able to get a roadworthy for a car with the stainless clasps (I did) – but VicRoads and engineers will not pass them.
Bit of a problem , because the RWC tester would have to pass a vehicle based on ADR,s if applicable or VicRoads standard . And VicRoads issues and monitors testers licence . If you look for the seatbelt requirements "quick release" I did see somewhere . What is the difference between trying to push an orange button to flipping a lever ?johnonetrillion wrote:You may be able to get a roadworthy for a car with the stainless clasps (I did) – but VicRoads and engineers will not pass them.
- johnonetrillion
Just the correct look for a restored car (in my case). On a resto-mod, hot rod or custom it's less of a deal. (But I reckon plenty of old school hot rodders would prefer to original look too.)FRANK BASILE wrote:What is the difference between trying to push an orange button to flipping a lever ?
And you are probably right re the ADRs etc.. In my case the clasps are original to the car and the rego is H plates.
