uni yoke
Re: uni yoke
http://www.driveshaftshop.com/domestic- ... 14mm-bolts That should do you.
Re: uni yoke
i just put a vx v6 and trans into a ford transit, the vx transmission had the same rubber coupling. i used a slip yoke out of an earlier commodore, same spline, same od. not sure what year it was out of but i think you will find that there is a heap that will fit. someone else on here will know a bit more. i am not conversant with gm transmissions but if like ford there is most likely not that many types as far as spline count and seal diameter. cheers.
Re: uni yoke
If that rear coupling is still slide fitted to a splined shaft and not a captive flange then the earlier 4L60 or 4L60E yolks should fit ,as T700 ..
Re: uni yoke
Thanks for the reply it is a slip in on a spline. So I will look for a yoke from an earlier trans .
Re: uni yoke
So maybe a VN or VP commodore one will do?FRANK BASILE wrote:If that rear coupling is still slide fitted to a splined shaft and not a captive flange then the earlier 4L60 or 4L60E yolks should fit ,as T700 ..
Re: uni yoke
Yes in my book .Mudgy wrote:So maybe a VN or VP commodore one will do?FRANK BASILE wrote:If that rear coupling is still slide fitted to a splined shaft and not a captive flange then the earlier 4L60 or 4L60E yolks should fit ,as T700 ..
Re: uni yoke
Thanks for the replys a yoke from a vp turbo 700 fits just fine so I'll have to jack up a commodore .
Re: uni yoke
VP had the 4L60 . Same anyway as the VN T700 .
Re: uni yoke
Thanks Frank my son has a trans and tailshaft out of a commodore and I tried the yoke in my trans and it fitted perfect so I'll have to check the model of the car it came out of and go from there. Will have compare the uni size of the jag against the commodore .
Re: uni yoke
I used Hardy Spicer uni's.
Number for the jag diff end (series 3 sovereign 1983) K5-13XR
Number for VN calais transmission end (1991) RUJ2038R / RUJ2038 I think the "R"just means regreasable? I used The R one.
Re: uni yoke
Thanks for the information its good to know that people are willing to share their experience. I'm a firm believer in paying forward and hope that I can help someone in the future. What comes around goes around.
- mgtstumpy
Re: uni yoke
Assuming a late box. If it is a Trimatic though ,be careful as they used different unis for 6 and V8 . The V8 version has a wider yolk . Better to use the beefier VN onwards .pilot48 wrote:Thanks Frank my son has a trans and tailshaft out of a commodore and I tried the yoke in my trans and it fitted perfect so I'll have to check the model of the car it came out of and go from there. Will have compare the uni size of the jag against the commodore .
