El Cheapo Build
- Big G
El Cheapo Build
I have just got home a start to my next project. The plan is to build a low cost rpu hotrod, all of this I have done before so hopefully it won't be too hard,
The chassis is a 1927 Hudson and at this stage I plan to leave the front and rear as parallell springs. The chassis is straight as a die and looks very sturdy. I have a 27 Dodge cowl and rear section off a tourer and will use this with new doors.
I pick up the donor V8 1991 Fairlane next Saturday, it is a 200k country car with aftermarket extractors. Every part will be used.
I also have a 1956 F100 disk brake front end which is a bit wide for the chassis spring mounts
<a
<a
Founding Oz E Rodder Member
I've lost the Plot
One day I will find it !
I've lost the Plot
Re: El Cheapo Build
That's exciting news Big G, I'm looking forward to following the build process
Re: El Cheapo Build
Subscribed.....dying to see it unfold
Al.
69 Camaro Z28 Clone....
- Mopar Mick
Re: El Cheapo Build
Cowl and chassis look to be in good condition Glynn.
I have a mint grille shell and grille badge here for your consideration when the time arrives.
Also have a dog bone radiator cap and motometer.
Mick.
Mick.
- chris spokes
Re: El Cheapo Build
nice
Re: El Cheapo Build
Cool stuff G.
I hope I can visit after Mulwala for a look.
- Big G
Re: El Cheapo Build
The chassis is solid the Hudson was a 9 seater so made a bit stronger it's nearly 200 mm depth in the middle.Mopar Mick wrote:Cowl and chassis look to be in good condition Glynn.
Mick.
The cowl has 2 small dents but only surface rust, the back section I may not use asit has the usual sloping back.
The grill I haven't decided on yet, I have a 1990's jag grill which inverted may suit in a track rod front.
I've lost the Plot
I've lost the Plot
Re: El Cheapo Build
Your build sounds and looks awesome Big G
I am keen to this progress too - it is refreshing to see something different to the norm
Re: El Cheapo Build
Nice work big G i'm excited to see the build progress.
- Big G
Re: El Cheapo Build
I am still setting up my small shed so everything has a place and easy to get to. I can't do much until I get the Fairlane home next Saturday and also I have to find the engineer that has been recommended to me. But in saying that, I can cut off the hanging pieces and bits on the chassis I don't need. Everything on the chassis is perfect, no damage so I will use the body brackets and hoping to use the engine mounts which are about where the Ford ones would be.
I've lost the Plot
I've lost the Plot
Re: El Cheapo Build
Should be fun to follow.
None of my builds ever stayed on track cost wise.
- Big G
Re: El Cheapo Build
zuffen wrote:Should be fun to follow.
THat is why I have bought most of the costly parts, I don't know if I will finish it but I am retired, 70yrs young and have a partime job, that along with a good wife who likes that I am active. Besides, I can always get my money back if I don't fiinsh it.
I've lost the Plot
I've lost the Plot
- Big G
Re: El Cheapo Build
I have finished cleaning up the chassis and have left the 3 original cross members and will get it sand blasted in a week.
I have been working on the body frame, it's only tack welded and I will leave the full welding to someone who knows what they are doing.
Next will be the doors
I've lost the Plot
I've lost the Plot
Re: El Cheapo Build
Looks like some very nice progress mate, your build will be finished before the Pilot at this rate.
- Big G
Re: El Cheapo Build
I have every intention of working on the car every day even if it's just for an hour.The only thing that will slow me down is money but I have everything from a donor V8 Fairlane which will be used.Chrisso wrote:Looks like some very nice progress mate, your build will be finished before the Pilot at this rate.
I've lost the Plot
I've lost the Plot
