A year or so ago I mixed up a batch of citric acid and used it with great results. I got the container out again and mixed it up well with a paint mixer on a cordless drill. I dropped a part in it for about 24 hours, and it came out clean as a whistle, just like before. I put in a water pump body that I am rebuilding, and forgot about it for a week... Idiot... now it has a crystal like coating over every surface that’s was not vertical in the bath. I’m supposing my only mistake was I left it in too long. Or have I gotten my use out of this batch of acid? I can’t be the first one to experience this... What is the best way to get the crystallized coating off? Or should I just spend the $100 on a rebuilt pump?
Thanks,
Citric acid issue
Citric acid issue
- 666
Re: Citric acid issue
I have had that happen myself, left a panel in to long and come out the same. After a number of attempts to get it off I pressure washed it, put it back in the tank for one day. Pressure washed again and problem sorted.hudson nut wrote:A year or so ago I mixed up a batch of citric acid and used it with great results. I got the container out again and mixed it up well with a paint mixer on a cordless drill. I dropped a part in it for about 24 hours, and it came out clean as a whistle, just like before. I put in a water pump body that I am rebuilding, and forgot about it for a week... Idiot... now it has a crystal like coating over every surface that’s was not vertical in the bath. I’m supposing my only mistake was I left it in too long. Or have I gotten my use out of this batch of acid? I can’t be the first one to experience this... What is the best way to get the crystallized coating off? Or should I just spend the $100 on a rebuilt pump?
Thanks,
I even had it lined up to get it sand blasted but re soaked it just to see what would happen. I take the panels out daily and wash off even if they need to go back in. Don't want to get caught again.
Regards Peter.
[color=#400040][i][b][list][size=85]-1923 T-bucket
I will try it. Thank you.
Me too, what Peter said...it works well.
