This followed me home
Re: This followed me home
Very nice and smooth.
Great work Ratty, I'm really enjoying watching you piece this back together 8)
rattyrod
Post by rattyrod »
A little bit more progress on the door . I needed a metal folder so instead of trying to buy one that would bend over a metre length I thought I would have a go at making one . While not giving a sharp bend over the full length it gives a good enough bend for what I need . I have since folded up the inner top of the door , the rear side panel with the door lock installed and made the return edge for the door skin mount . I still have to get the right shaped curve in the lower 100 mm as I have nothing to go on
ramp
Post by ramp »
Looking good Ratty.
Cruzin for the SON
Member Chrysler Restorers Club of Aust. (Vic)
Newbee
Post by Newbee »
Lots of work in those doors Ratty, you are doing an excellent job.
Magic metal work Ratty, thanks for sharing the detail of building the doors.
rattyrod
Post by rattyrod »
Update for the week , shaped up the front door frame section and the outer top of the door which is now a straight finish to match the new glass ( wood ) .I also installed the caprice intrusion bar while I was at it . Just the lower section to make and that should be it for the frame
Lenny keeping an eye on proceedings
Intrusion bar in , will be welded in later
The top will be trimmed once the skin is in position
A quick mock up
Bought one of these from Aldi , cheap enough to learn on and was spending a small fortune on grinding blades
chris spokes
Post by chris spokes »
nice work there Pete 8)
Nice blending with the door [old and new technology] . I got one of those Aldi Plasma cutters a few years back on a previous sale ,different brand. Works a treat cuts up to 10mm. As for cut off discs. When the Wantirna Trash,n Treasure is operating I get my discs from a Chinese bloke who is a regular selling tools and hardware, he has discs in packs ,something like $10 for 20 or 25. of the small size. Both sizes for my angle grinders, and flap discs at a fraction of Bunnings prices.
Ratty great skills and ingenuity mate this will be one very special ride when it's done. Cool as mate. 8) 8) 8) 8) 8) 8) 8) 8) 8)
Very nice fab work their mate.
Takes a lot of nutting out and time to get it all to run smoothly.
rog
Post by rog »
I found smith & arrow on eBay to be fairly cheap for cutting/sanding discs, even have roloc discs for small air sanders. Good tip with plasma cutting is to leave a little on & sand/file back to a clean edge for welding. Great looking work on the doors etc, the plasma will make it so much easier to cut steel.
Post by steve the ford guy »
My old plasma cutter has a filter for the compressor air that uses a toilet roll, not as much fun now sourcing replacements as in the past you had to wrestle them away from other shoppers :mrgreen:
rattyrod
Post by rattyrod »
I have had a 2 week break from working on the ute due to some shutdown rail work and swapping engines in Jets commodore which came about by low oil , water and high revs resulting in a spun bearing :evil:
This week I finished off the rear pillar and latch , which is a combo of old and new metal and have left it a little bit longer than needed for now . The sides aren’t fixed to this as yet . I want to get the door areas finished such as hinged properly so this means some rust removal and repair first before strengthening and rebuilding the front pillar
I am trying to make things a little bit longer than needed as I don’t have a finishing line from here to the rear quarter panel as yet
Smart thinking Peter but what else would I expect from you. 8) 8) 8) 8) 8) 8)
